Thread: Carrier 30 HXC 261 1.5 Kw/Ton?
30-11-2010, 03:02 PM #1
Hello everyone,
first of all I'm new to this forum and new to refrigeration. Im a internship do research for a hotel improving the refrigeration. I'm doing a investment project for if they replace parts inside the refrigeration system.
So my setup is to calculate first the current installation. (Chiller-, airhandler-efficiency). The chiller, Carrier 30 HXC 261 (252 ton) got an efficiency in the books of 0,72 kW/ton. Now I have measured the chiller on full capicity 100% and it's using 1.5 kW/Ton. How is it possible to be twice inefficiënt than the data in the books?
Chiller is 10 years old, but I read something about losing 1% efficiency a year. So 50% is pretty much.
Does any of you know any solutions for me? What I have the test more? How to find the leak?
Also I'm thinking about asking prospects of the McQuay Magnitude chiller. Anyone expierence with this chiller?
Any suggestions/help is welcome, I'm a rookie into refrigeration.
30-11-2010, 04:06 PM #2
Re: Carrier 30 HXC 261 1.5 Kw/Ton?
Maybe not bad to add.. The chiller uses 3 compressors, two of 80 ton and 1 of 60 ton...
30-11-2010, 07:48 PM #3
HJi, can't seem to find any data on the 30HXC 261; do you have any more data on the model type, Phase number etc? Also, duties normally quoted on kW.
30-11-2010, 08:21 PM #4
30-11-2010, 08:25 PM #5
google: carrier 30hxc chiller
Than the first link, I can't post links cuz I havn't got 15 posts yet :S
14-12-2010, 02:29 PM #6
Topic can be closed. Found out the problem, defect kW-meter.. great.
Carrier Chillers
By Ed Burris in forum Technical DiscussionsReplies: 6Last Post: 27-03-2010, 02:00 AM -
Carrier 42XPF100 spares availability
By rob_h1978 in forum Air ConditioningReplies: 0Last Post: 11-02-2010, 11:08 AM -
Geoff in NY ~ Carrier Parts
By Futsal1st in forum Trouble ShootingReplies: 6Last Post: 30-12-2009, 04:07 AM -
Help identifying carrier HiWall dom. split
By paul_h in forum Air ConditioningReplies: 4Last Post: 12-12-2008, 09:12 AM
