Results 1 to 1 of 1
29-11-2010, 08:31 PM #1
R410A type compressor in a R407C application
Hi there,
I have replaced an original bad compressor LG HR061Y with Copeland ZP54-K5E. The ZP54 is primarily designed for R410A. What changes in power I can expect when I use R407C with this compressor. The unit is AirWell GCN 43 RTC and primary used as heat pump with indoor heat exchanger to water. Also I had to change bad part with orrifice and one way valve. Because it is impossible to buy as spare part, I have used TEV TMVX-00101 with orifice #3,5.
Thank you, Ivo.
R407C and R410a for low temperature
By Tanja in forum RefrigerantsReplies: 15Last Post: 19-01-2011, 08:28 PM -
rotary type replacement compressor in place of a piston type unit
By frozenpal2010 in forum Air ConditioningReplies: 1Last Post: 06-09-2010, 05:37 AM -
Pipes to large for R410a??
By Spanglishsparky in forum Technical SpeculationsReplies: 6Last Post: 09-05-2009, 12:57 AM -
vertical oil separator or horizontal type?
By cygbob in forum Industrial CompressorsReplies: 6Last Post: 30-04-2009, 10:13 PM -
Pumpig R404a; R410a; R407c
By Konstantin in forum RefrigerantsReplies: 2Last Post: 08-11-2007, 05:56 PM
