Results 1 to 18 of 18
    Dec 2006
    Indonesia
    74
    37
    Question about calculating BTU
    Hi, I do have a couple of question, let's say I have a pond with 1000 liter of water and I'd like to bring the temperature down to 4 degree Celsius, how much BTU do I need? And how do I calculate the diameter and length of the caliper pipe?
    Thank you in advance!
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Question about calculating BTU
    It depends what temperature the pond is before starting cooling
    1 BTU is the energy necessary for cooling 1 pound of water by 1°F.
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by ysh1317 View Post
    My question is why are you quoting metric, then trying to work out in BTU`s which is an imperial measurement
    My wife used to say you never listen to a word I say at least I think that what she said
    Mar 2006
    Merate (LC) - Italy
    2,549
    That's easy. Split systems are sold by the BTU/h, which is an awful habit and should be deemed as unlawful in EU
    Jun 2009
    North East England
    41
    712
    Quote Originally Posted by NoNickName View Post
    We buy ours in Kw's.
    Apr 2009
    Panacea, Florida
    87
    One btu will change the temperature of one liter of water by 1.23 degrees C. So to cool 1000 liters from 15 to 4C will require removing about 9000 btu from the water. Unfortunately, I have no idea what a caliper pipe is.
    11,025
    Caliper Pipe probably equals a capillary tube, use Dancap.
    http://www.danfoss.com/BusinessAreas...ils/DanCap.htm
    Aug 2009
    New Zealand
    2,554
    26
    Quote Originally Posted by dougheret0 View Post
    I do not think so.
    some clues
    1 litre of water weighs more than a pound of water!
    1F is a smaller energy value than 1C
    look at Nonicknames description above
    Best to use either imperial or metric to stop confussion
    Have ago again?!
    Mar 2006
    Merate (LC) - Italy
    2,549
    Let's do it in metric.
    1000 Kg x 1 Kcal/KgK x 11K = 11000Kcal = 43651 BTU.
    If you want to cool it in one hour then you need a chiller by the capacity of 43651 BTU/h or 12.4 kW.
    Dec 2006
    Indonesia
    74
    37
    Thanks for all the replies so far, so helpful.
    I am from Indonesia btw, nice to see all of you
    Dec 2006
    Indonesia
    74
    37
    Another question, is it possible to bring the temperature of 1000 liter of water down around 4-8°C with 9000 BTU chiller? Ambient temperature is around 30-31°C.
    If it is, any tips and trick to do so? Or is it too much for a 9000 BTU chiller? Thanks and sorry for the basic question
    Mar 2006
    Merate (LC) - Italy
    2,549
    I think you mean BTU/H e not BTU.
    Yes, it is possible, but instead of taking one hour, it will take 43651/9000= slightly more than 5 hours
    Dec 2006
    Indonesia
    74
    37
    The reason I am asking that is because I tried do it with a 9000BTU/H HBP rotary compressor, but I wasnt able to get the water down even to just 10°C. I wonder what I did wrong? Perhaps the sizing of the pipe is incorrect?
    Mar 2006
    Merate (LC) - Italy
    2,549
    It means that the insulation is not enough or that the unit is not performing as declared.
    Jun 2010
    Yorkshire
    59
    520
    What are the dimensions of the pond? is it long and shallow having a large contact area with the air, or short and deep with a small contact area with the air, and what is the RH of the air? And what method of heat exchanger are you using? Ie a direct pump system thats capable of moving the total volume of water very quickly via a cooling tower then through a double walled evaporator, or an evaporator directly submerged in the pond, or a glycol/brine coil/loop submerged directly in the pond?
    Dec 2006
    Indonesia
    74
    37
    Quote Originally Posted by chilliwilly View Post
    The dimension of the tank is 100cm wide and 60 cm deep, I've tried both with direct pump and submerged evaporator with bad result... I wonder what can be done to fix it. Thanks for the response
    Mar 2006
    Merate (LC) - Italy
    2,549
    It also depends at what conditions the cooling capacity is declared.
    Apr 2009
    Panacea, Florida
    87
    Nonickname's calculation is correct. My unfamiliarity with SI led me to an error. Glad it was picked up.
  1. Oil Capacity Question
    By Z2TT in forum Transport
    Last Post: 02-01-2010, 08:24 PM
  2. Question about calculating compressor power
    By ysh1317 in forum Fundamentals
    Last Post: 23-10-2009, 12:57 AM
  3. Replies: 1
    Last Post: 02-06-2009, 04:01 PM
  4. Refriferation cycle question
    By ozmecheng in forum Fundamentals
    Last Post: 26-03-2008, 10:38 PM
  5. r134a question, calculating heat lost by refrigerant
    By kamikazi929 in forum Fundamentals
    Last Post: 03-01-2008, 08:19 PM
