Results 1 to 8 of 8
    Sep 2009
    libya
    41
    35
    monoethylene glycol preparation
    Hello everybady,
    I used to Calcium chloride solution as a second coolant but now i want to change it by monoethylene glycol so how can i prepare this solution to get set point (-40)? Quantity of solution 1000 liter
    Thanks on advice
    Sep 2009
    libya
    41
    35
    Re: monoethylene glycol preparation
    i mean Monopropylene Glycol not monoethylene glycol
    11,025
    Somerset
    69
    4,697
    Good link as usual Brian.
    Thanks Grizzly
    Sep 2009
    libya
    41
    35
    Thanks alot Brian
    Nov 2004
    China
    176
    Be careful. If you are changing and existing system. CaCl2 and Glycols do not mix. The stsrem must be 100% flushed of Calcium chloride before adding glycol.
    Jul 2005
    61
    68
    Are the two interchangable as far as pump, and line sizing?
    Sep 2009
    libya
    41
    35
    Quote Originally Posted by McFranklin View Post
    Hi everybody and many thanks
    we like to use Monopropylene Glycol instead of Calcium chloride for the same machine so the same pump and the same lines but maybe we will face problem with viscosity. i do not know what shall i do? any advice?
    Regards & Thanks
  1. Converting a system that uses ammonia to use glycol
    By metallicork in forum Technical Discussions
    Last Post: 25-11-2010, 12:50 AM
  2. glycol
    By thebigcheese in forum Technical Discussions
    Last Post: 04-01-2010, 07:20 PM
  3. glycol cooling system for soft dring
    By faryuki in forum NH3
    Last Post: 21-04-2007, 03:44 PM
  4. Milk getting into glycol on chill press
    By balerjoe in forum Trouble Shooting
    Last Post: 06-09-2005, 09:41 PM
  5. which glycol to use ?
    By dchatta in forum Refrigerants
    Last Post: 12-07-2004, 09:26 AM
