Results 1 to 2 of 2
    mr wilks's Avatar
    mr wilks Guest
    I have a problem with a nice ice
    Hi I am new to this forum, help would be greatly appriciated, I have a nice ice N25P which starts as you would normally expect, when the cubes get about 1mm thick the ice tray drops and empties all the water, the coil stays refrigerated but the tray motor dosen't come back up, any surgestions outthere, thanks mr wilks
    Oct 2008
    mallorca, spain,
    75
    768
    Re: I have a problem with a nice ice
    mr wilks, your ice maker is faulty, it appears that the defrost is at fault, have you a local fridge engieer,?
  1. MFI AMP6855 defrost problem
    By gliderpilot47 in forum Domestic
    Last Post: 12-01-2011, 12:11 PM
  2. Danfoss ICAD/ICM Valve problem
    By piewie in forum NH3
    Last Post: 11-09-2010, 09:20 AM
  3. problem with GE air con power problem
    By Richie101 in forum Air Conditioning
    Last Post: 05-11-2009, 04:00 PM
  4. mycom 4wb unloading problem
    By samlee12 in forum Industrial
    Last Post: 19-01-2009, 10:21 PM
  5. Toshiba RAS 13 SKV problem....
    By igi in forum Air Conditioning
    Last Post: 12-01-2009, 08:03 AM
