Thread: R 404a for r 402 a dorin comp
24-11-2010, 02:26 PM #1
I have a compressor dorin k 300 sb use r402a pls can you inform me if i can use another refrigerant ( for example r404 a)
24-11-2010, 05:02 PM #2
Re: R 404a for r 402 a dorin comp
if the compressor and the installation is filled with old type oil (3GS), than you have to retrofit, changing the oil with syntethic oil. if there is not more than 3% old oil inside the compressor, you can change to the new gas R404A.
if the compressor is older than about 15 years, best ask the factory.
24-11-2010, 05:03 PM #3
I think so. For R404A just check if the current draw by the compressor motor will still be acceptable.
404a Charging CONFUSION
By ZeroTolerance in forum Trouble ShootingReplies: 11Last Post: 13-05-2010, 09:48 AM -
Third comp change in three years, why?
By expat in forum CommercialReplies: 44Last Post: 16-10-2008, 03:48 PM -
2 Stage Comp Defrosting
By jwasir in forum FundamentalsReplies: 0Last Post: 27-08-2008, 09:10 PM -
comp oil
By headgasket in forum Technical DiscussionsReplies: 2Last Post: 14-10-2007, 07:34 PM -
R 404a
By Samarjit Sen in forum RefrigerantsReplies: 59Last Post: 07-08-2007, 06:35 PM
