    pipoy-ito's Avatar
    pipoy-ito Guest
    Hourly building load factors
    Guys,
    would really appreciate it if somebody here knows how to calculate an Hourly Building Load Factor for A/C systems.
    if there is an exel file of it then it would be even nicer.
    thanks,
    Pirso
    Nov 2010
    Germany
    120
    14
    Re: Hourly building load factors
    Radiant time series. This is the link
    http://www.google.com/url?sa=t&sourc...9w2WGQ&cad=rja
    i have something what is valid only for Germany..and it doesn't work so it is better to use thin thing. It is not very practicable but it will use....
    we had a trial version of this program and i am making a pressure in my company for purchasing.
    http://www.4msa.com/FineHvacENG.html
    But if you want to do it manually, refer to the manual J. The book is cca50Euros and it has software on CD..
    Enjoy
  1. how to calculate the heat load of room or building
    By sunilsaini in forum Trouble Shooting
    Last Post: 30-05-2010, 10:05 AM
  2. Replies: 3
    Last Post: 31-03-2009, 06:56 PM
  3. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  4. Compressor loading, cooling, and range of operation.
  5. Heat Load Calculations - Part L Building Regs
    By Refrigerologist in forum Tools and Calculators
    Last Post: 12-03-2008, 09:53 AM
