Thread: r404a
23-11-2010, 12:42 PM #1
r404a
Is there anyone wants to explain me,why r404a is always charge at liquid?and not in gas,pls.help me.....thanks
23-11-2010, 01:21 PM #2
Re: r404a
As with all belnded refrigerants which are identified with the 4 at the start of the R number are either zeotropic or aziotopic blends which are at different states at the same temp/pressure you need to charge as a liquid to ensure that the blend is kept correct
by blends means several different refrigerants comined to make 1
23-11-2010, 02:35 PM #3
Re: r404a
If you have sure that you will evacuate all the refrigerant that is inside the vessel you don't need to charge on the liquid phase. However I think that for R404A (near azeotropic) if you charge on the vapor even if you let refrigerant on the vessel the consequences wouldn't be great.
Max low side pressure in R404A system
By Wilade in forum Technical DiscussionsReplies: 8Last Post: 25-08-2009, 09:23 PM -
Accidentally mixed R404A with R134a
By toma in forum Trouble ShootingReplies: 1Last Post: 13-08-2008, 03:33 PM -
R507 to R404a
By Andy AC in forum CommercialReplies: 2Last Post: 09-08-2008, 05:36 PM -
Why not R404a?
By afak in forum Technical SpeculationsReplies: 12Last Post: 02-04-2007, 08:58 PM -
R134a or R404a
By jingua_ph in forum RefrigerantsReplies: 4Last Post: 27-09-2006, 03:31 PM
