Thread: r404a
    rac tech's Avatar
    rac tech Guest
    r404a
    Is there anyone wants to explain me,why r404a is always charge at liquid?and not in gas,pls.help me.....thanks
    Jun 2009
    North East England
    41
    712
    Re: r404a
    As with all belnded refrigerants which are identified with the 4 at the start of the R number are either zeotropic or aziotopic blends which are at different states at the same temp/pressure you need to charge as a liquid to ensure that the blend is kept correct
    by blends means several different refrigerants comined to make 1
    Dec 2008
    Portugal
    48
    1,020
    Re: r404a
    If you have sure that you will evacuate all the refrigerant that is inside the vessel you don't need to charge on the liquid phase. However I think that for R404A (near azeotropic) if you charge on the vapor even if you let refrigerant on the vessel the consequences wouldn't be great.
  1. Max low side pressure in R404A system
    By Wilade in forum Technical Discussions
    Last Post: 25-08-2009, 09:23 PM
  2. Accidentally mixed R404A with R134a
    By toma in forum Trouble Shooting
    Last Post: 13-08-2008, 03:33 PM
  3. R507 to R404a
    By Andy AC in forum Commercial
    Last Post: 09-08-2008, 05:36 PM
  4. Why not R404a?
    By afak in forum Technical Speculations
    Last Post: 02-04-2007, 08:58 PM
  5. R134a or R404a
    By jingua_ph in forum Refrigerants
    Last Post: 27-09-2006, 03:31 PM
