Thread: Whirlpool ISPRAC Control Panel
22-11-2010, 11:42 PM #1
Hello folks,
I have an ISPRAC control panel 08232484R1 that is faulty. Does anyone know where I can get one cheap or does anyone know a common fault on the board?
It belongs to a whirlpool fridge freezer model No. ARC 7610.
Any help on this would be much appreciated.
Kind Regards
A Chara
23-11-2010, 08:15 AM #2
Re: Whirlpool ISPRAC Control Panel
What is the fault ?
also there is a 12 digit number on the model plate which defines the different versions of the 7610.
BG
23-11-2010, 02:14 PM #3
Sometimes the fridge works and sometimes it dosent. If I twist the thermostat down and back up it works for a while. The sticker with the model number inside the fridge has been taken off. There is a sticker on the back with the following numbers:
90361921000
0033175
The fridge is 2 meters high by 600 wide with freezer on the bottom.
24-11-2010, 07:28 AM #4
You would need to check the fridge and freezer sensors with a meter before changing the board.
Any frost build up in freezer ? (frost free,but could be fault).
If there is any sign of frost then switch off for 24 hours, both fridge and freezer.
24-11-2010, 07:34 AM #5
Double post !
Quantum LX Control Panel
By Trevor1 in forum Trouble ShootingReplies: 2Last Post: 08-05-2010, 01:46 PM -
Bosch Fridge Freezer Control Panel Problem
By Bork in forum DomesticReplies: 1Last Post: 25-08-2009, 01:02 AM -
Wrong temperature on control panel
By swee'pea in forum Trouble ShootingReplies: 2Last Post: 14-01-2009, 09:18 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Whirlpool 20RI D3 Control Panel Problem
By broadmate2003 in forum Trouble ShootingReplies: 1Last Post: 27-01-2008, 09:17 PM
