Thread: Psi
22-11-2010, 11:53 AM #1
Psi
What psi should you pressure test a split at
22-11-2010, 11:56 AM #2
Re: Psi
james , tell me what are you pressure testing with? and what gas are you going to use in the unit?
22-11-2010, 12:01 PM #3
Re: Psi
R134a on a college work shop fridge system sorry not split
22-11-2010, 05:49 PM #4
Re: Psi
Map x 1.3 for pressure test
map x 1.1 for leak test
MAP= REFRIGERANT PRESSURE AT 55C AIR COOLED)(45C WATER COOLED
MAP- maximum allowable pressure
But your tutor should have told you this before setting you the problem also you should be working in Bar unless your in Dartford USALast edited by james10; 22-11-2010 at 05:53 PM.
27-11-2010, 11:09 PM #5
Re: Psi
Bar, psi, can't see why the units of measurment make a difference. If you want to go really Euro then wouldn't Pascals be better as that it is the SI unit?
Use the factors as mentioned above for official strength and leak testing. You will need to use gauge pressure as opposed to absolute.
Cheers,
28-11-2010, 10:05 AM #6
28-11-2010, 11:22 PM #7
Re: Psi
Hi James,
Sorry, I see where your post was coming from now.
I assumed the Euro link as that was the only reason I could see why it would be measured in Bar. Still, as the old man always told me - never assume.
I remember in the first year of college the tutor telling us 'you can't teach someone how to braze, you can either do it or you can't'. Sounds like the same bloke!
Cheers,
