Results 1 to 2 of 2
    ratliffr's Avatar
    ratliffr Guest
    Manifold hose-seal replacement
    Hello,
    I am in a fulltime HVAC course here in Cincinnati,Oh and I recently put new seals in a set of hoses I have been using.They would leak fairly bad.I realize that I had probably tightened the hoses to tight too many times.With the new rubbers in should they sit flush or stick up past the schrader core needle?When I put them in I just push them down as far they would go and then I would screw in a new ribbed brass insert until it would bottom out as well.I would like to fix them properly before class or I would ask my instructor.Thank you all.
    Feb 2010
    242
    Re: Manifold hose-seal replacement
    Quote Originally Posted by ratliffr View Post
    Hello,
    They will sit proud a little.
    Sounds to me like you have replaced them perfectly.
    Try them and see how they work.
    all the best
    coolrunnings
  1. Halls shaft seal replacement
    By Loafa in forum Industrial Compressors
    Last Post: 02-08-2010, 03:46 AM
  2. New Digi-Cool® Paradigm™ Manifold
    By HVACGod in forum Tools and Calculators
    Last Post: 23-12-2009, 03:21 PM
  3. Manifold Gauge and Hose question
    By lees8110 in forum Air Conditioning
    Last Post: 10-06-2009, 10:51 PM
  4. Frick shaft seal leaking
    By Ian B in forum Industrial Compressors
    Last Post: 27-01-2009, 10:31 PM
  5. Hose is too short!
    By peterfoster in forum Domestic
    Last Post: 01-06-2008, 09:25 PM
