20-11-2010, 10:40 AM #1
Whirlpool 20RB D4, side by side American fridge freezer not getting cold.
I have a whirlpool american fridge/freezer which is now 3 months out of warranty and just developed a fault. The fridge and freezer have stopped getting cold but the display says all is fine -18 for the freezer +4 for the fridge . I first noticed that the ice cubes were melting, so i checked the food and sure enough the frozen food on the top couple of shelves was getting soft , i removed all the food . It will not make ice cubes either , but the back wall of the freezer unit is icing over quite badly which it has never done before. There are no red lights or anything flashing on the display panel. The motor still seems to run ok , this can be heard.
Any suggestions ???
20-11-2010, 05:37 PM #2
Re: Whirlpool 20RB D4, side by side American fridge freezer not getting cold.
I'd just like to add , the water works ok and is chilled and the ice dispenser works fine. It doesn't produce the ice to fill the bucket.
29-11-2010, 12:05 AM #3
One of the following is bad: defrost timer/board, defrost termination thermostat/bi-metal, or defrost heater.
05-12-2010, 11:37 PM #4
15-12-2010, 11:34 AM #5
G'Day,
We had an identical problem with our side by side fridge - temp displays OK but ice melting. Turned out the vents at the rear of the frig are located near the floor and were almost blocked with hairs/dust etc which stopped airflow to the compressor. Spoke to a repairer and he said this problem was fairly common especially with newer smooth back Korean made fridges and usually overlooked. Sometimes the fix is simple.
Good Luck.
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
No ice!! Please help!! Whirlpool american style side by side fridge freezer
By mandiz in forum DomesticReplies: 3Last Post: 20-01-2010, 05:27 PM -
By mandiz in forum Trouble ShootingReplies: 0Last Post: 17-01-2010, 07:50 PM -
Zanussi ZNB 3850 Fridge warm, freezer cold
By thenotts in forum DomesticReplies: 2Last Post: 02-11-2009, 10:05 PM -
Freezer not cold enough, Fridge too cold
By barrance in forum CommercialReplies: 4Last Post: 06-12-2001, 06:11 PM
