19-11-2010, 07:34 AM #1
Carrier 5H40 Compressor not loading up.
After rebuilding my carrier 5H40 compressor, the compressor is not loading.
19-11-2010, 08:58 PM #2
Re: Carrier 5H40 Compressor not loading up.
OK then, check everything that you have done and confirm that it has been re-installed correctly.
19-11-2010, 10:16 PM #3
Is it electric loading or suction loading?
18-02-2011, 01:48 PM #4
did u test the hydrolic relat before installation, is oil pressure ok and cop? normally it should be tested when u instalcylinder sleeve above the unloader fork. try checking by giving pressure externally. is the capacity control valve ok? bellow not leaking. check carrier site for documentation.
Carrier Chillers
By Ed Burris in forum Technical DiscussionsReplies: 6Last Post: 27-03-2010, 02:00 AM -
Carrier 42XPF100 spares availability
By rob_h1978 in forum Air ConditioningReplies: 0Last Post: 11-02-2010, 11:08 AM -
Geoff in NY ~ Carrier Parts
By Futsal1st in forum Trouble ShootingReplies: 6Last Post: 30-12-2009, 04:07 AM -
Help identifying carrier HiWall dom. split
By paul_h in forum Air ConditioningReplies: 4Last Post: 12-12-2008, 09:12 AM
