Results 1 to 2 of 2
Thread: citi multi please help
16-11-2010, 06:35 PM #1
hello, i have a puryp108gtmua with a pefyp36nmhue indoor coil attached. it is not calling for the electric back up heat. i understand cn24 on indoor board should energize with dc12volts when room temp falls 4 degrees below set point. i can watch on maintaince tool and set room temp 10 degrees above return air temp and still measure o volts at indoor coil board. is there a dip switch that may be set wrong or will i need a new control board for indoor coil. any help would be great
16-11-2010, 08:56 PM #2
Re: citi multi please help
You can use a third party equipment for operating electric backup heaters. Look for ThermoPad..
citi multi question
By kklobas in forum Air ConditioningReplies: 6Last Post: 16-08-2010, 06:03 PM -
daisychain citi multi
By cavalieri85 in forum Trouble ShootingReplies: 1Last Post: 23-07-2009, 04:12 PM -
mitsu citi multi problem
By philjd26 in forum Air ConditioningReplies: 6Last Post: 09-01-2009, 05:06 PM -
Multi temp installations
By nova in forum TransportReplies: 6Last Post: 13-09-2008, 09:38 PM
