16-11-2010, 06:15 AM #1
Appropriate thickness of rubber insulation
Need help re: appropriate thickness of rubber insulation needed for a low temp. refrigeration system with an evaporating temp of -38 degC. We need to replaced the old one since it is already developed a condensation that is really keeping the ceiling of the room where the pipe runs wet all the times especially when it defrost (hot gas defrost).
Thanks,
17-11-2010, 02:56 AM #2
23-12-2010, 06:55 PM #3
Re: Appropriate thickness of rubber insulation
24-12-2010, 04:59 AM #4
You will need at least 60mm to avoid condensation there,,,,,i would not think about using rubber as it will eventually fail,,,look at using polyeurethane at least 50mm thick would be a starting point if yoou want it done right.Lawrie
24-12-2010, 05:05 AM #5
For low temperatures Polyurethane foam is better suited than Nitrile rubber.
24-12-2010, 12:05 PM #6
Thanks guys, it will help a lot.
Acoustic Insulation for Ductwork
By titanum456 in forum IndustrialReplies: 3Last Post: 17-08-2010, 11:09 PM -
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
pipe insulation thickness
By bangoman in forum Air ConditioningReplies: 3Last Post: 24-04-2008, 08:43 PM -
Emmisivity as insulation thickness determinant ?
By sharshal in forum Technical SpeculationsReplies: 4Last Post: 23-10-2006, 02:26 AM -
reduce thickness of bended copper tubes
By rlim in forum Air ConditioningReplies: 4Last Post: 08-07-2003, 10:58 PM
