    Bojan Bojanic's Avatar
    Bojan Bojanic Guest
    SuperHeat Setting
    Hi All,
    Got a bit of a debate going here about setting superheats.
    Case:
    Evaporator temperature (converted from pressure)
    -24 Celsius
    Temperature at the bulb -20
    Is that a correct way to set 4K superheat or should the temperature at the bulb be -28??
    38
    Re: SuperHeat Setting
    Hi Bojan.
    go to www.kueba.de and look for the service tools area.
    3,853
    Found this on the sporlan/parker site
    http://www.parker.com/literature/Spo...nous/Form1.pdf
    Basically if you are evaporating at -4C for example which you have determined by taking the pressure at the evaporator outlet and converting that pressure into temperature with a pt chart, you then take the temperature at the outlet and compare the two, say its 3C then you have 7K superheat. Its K for Kelvin as its a difference in temperature and not an actual temperature.
    Jon
    Last edited by monkey spanners; 23-12-2010 at 11:04 PM. Reason: must type quicker!!!!!!
    Oct 2003
    5,630
    Quote Originally Posted by Bojan Bojanic View Post
    -24 Celsius
    You have indeed 4K superheat, if you should have -28°C, then you have subcooled instead of superheated gas.
    Which isn't possible in an evaporator.
  1. Superheat and Subcooling
  2. TEV superheat setting and low temperatures
    By DaBit in forum Fundamentals
    Last Post: 01-03-2010, 02:11 AM
  3. setting superheat
    By sidi in forum Air Conditioning
    Last Post: 20-05-2008, 05:06 AM
  4. setting up a unit using superheat
    By marc5180 in forum Trouble Shooting
    Last Post: 26-06-2007, 11:25 AM
  5. Setting superheat settings
    By Abe in forum Commercial
    Last Post: 10-06-2004, 02:20 PM
