Thread: Queries regarding heat pump.
13-11-2010, 12:13 PM #1
Dear friends, I have following queries.
1. Can we get temperature of 80 deg. in Air source heat pump?
2. Can we pass furnace oil instead of water, so it can be used as a preheating of furnace oil applications?
13-11-2010, 02:22 PM #2
Re: Queries regarding heat pump.
Yes & yes (needs careful design for the condenser - secondary loop would be safer though. Then some dT lift is lost due HE).
What COP do you require? This may end up making nonsense of the prospective energy savings.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
23-11-2010, 10:36 AM #3
@ desA
How would you specify the heat exchanger for the furnace oil, with the specific density of oil being different to that of a glycol water mix?
23-11-2010, 10:47 AM #4
Very carefully.
23-11-2010, 12:31 PM #5
lol, thanks for the input desA, but say if I specifically wanted to size one up, what variables would I have to take into account?
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
House heat pump use in Croatia
By David Hu in forum Heat PumpsReplies: 1Last Post: 03-07-2009, 08:06 AM -
Calorex 510 Heat pump question
By jugglerb in forum Heat PumpsReplies: 8Last Post: 21-06-2009, 10:49 AM -
Heat pump hot water system
By kiamaian in forum Technical SpeculationsReplies: 4Last Post: 16-06-2009, 06:48 AM -
Will this heat pump work?
By goodguy in forum Heat PumpsReplies: 7Last Post: 08-03-2008, 05:14 PM
