11-11-2010, 12:20 PM #1
maytag side by side f/f forming ice!
hi my maytag fridge+frezeer side by side model GS2928EEDW/11. I will appreciate any help or advise on this problem.Thanking all in advance. i am not an engineer.
1.The problem is on the freezer side it seems to work ok but am finding ice patches under neath the last storage tray (bottom tray). I am assuming (may be am wrong) this is coming from inside the frezeer from the back freezer wall which has a grill.
2. before writing this i turned the setting switch down that is from mid temp to down and as as expected the freezer swithed off and when i turned the switch to high temp the freezer is quiet its not kicking in.
am not sure what is happening!!
11-11-2010, 01:19 PM #2
Re: maytag side by side f/f forming ice!
please note no 2. the freezer is ok up and running but i have problem with my point number 1 which is icing up!
11-11-2010, 05:34 PM #3
The drain hole is blocked
11-11-2010, 06:04 PM #4
Hi Lucky thanks very much for your help.
Any idea where i can download manual for this particular uk model. The magtag website doesnot recocnize this model!!
thanks
Ice forming on suction side flare / valve area
By airconlad in forum Air ConditioningReplies: 4Last Post: 02-06-2010, 11:49 PM -
Side by Side TPG21PRXFBB
By michel_engelen in forum DomesticReplies: 2Last Post: 26-05-2010, 08:57 AM -
samsung side by side sr-s2028css
By sork in forum Technical DiscussionsReplies: 2Last Post: 26-06-2008, 09:06 PM -
Maytag side by side auto defrost problem
By m0t in forum DomesticReplies: 4Last Post: 02-06-2008, 12:47 PM
