Results 1 to 1 of 1
Thread: scotsman mvh450
11-11-2010, 09:44 AM #1
scotsman mvh450
Hi having issue with ice machine .
Had a faulty tx valve
Unit running in vaccuum and hi head pressure replaced valve and orifice , pressure tested ok vac ok added correct charge . Run system pressures normalised
-5c / 10 suction and 35c head pressure .
After 20mins running water temp in trough 0.4c all i can get now is get the bottom half of the evaporator plate to create ice . I adjusted the tx valve and adjusted gas charge .
- I dont specialise in ice machines but does this sound like an evaporator issue why do i have ice forming on bottom but not top .
Thanks any help greatly appreciated .
Scotsman CME256 Water Diagnostic Light
By alphamarcaphi in forum Trouble ShootingReplies: 3Last Post: 31-12-2010, 04:48 PM -
Scotsman sce170 trouble
By lowenherzig in forum CommercialReplies: 3Last Post: 11-03-2010, 03:44 AM -
Scotsman Ice Machine, help, please
By tom_xox in forum CommercialReplies: 17Last Post: 22-01-2010, 06:05 PM -
scotsman mv600 fault
By Colin G in forum Trouble ShootingReplies: 16Last Post: 31-07-2009, 11:43 PM -
Scotsman CS60 no ice
By docgreen9 in forum DomesticReplies: 3Last Post: 14-03-2009, 02:45 AM
