Thread: Help me pls
02-11-2010, 10:23 PM #1
Help me pls
i will design small chiller system (2-4)RT but i need to initial point for start.
one problem is how to select the cold water container size ?
second stage how to select capacity of compressor for compression cycle so as given cold water .
Finally;Best regards
02-11-2010, 10:52 PM #2
Re: Help me pls
First item - find book on theory of refrigeration, study it.
Second item - Contact refrigeration expert to design it for you.
Without correct knowledge you can not design.Brian - Newton Abbot, Devon, UK
13-12-2010, 07:28 PM #3
Re: Help me pls
Start from a refrigerant cycle and when you understand what is happening, come back and you will have some help definitely.
