Results 1 to 2 of 2
Thread: a-moan-ya
    treeman's Avatar
    treeman Guest
    a-moan-ya
    I recently salvaged a office size frige and drove it around on my flatbed for a month before I found out it was powered by NH3. I wanted to recycle it but could not find any safe way to remove the refrigerant. Next I got into a conversation with a young kid who is primarily a tubehead (repairs and rebuilds tube guitar amps), and he had seen a similar box, and advised that I plug it in to see if it would operate, My first attempt failed as I was unaware of the warm up period required, and when nothing was happening, I chalked it up a loss, but of course it only needed a few minutes to get the gas hot and works fine. It became the perfect solution to store several bottles of vet grade antibiotic (more salvage), but now I am wondering if it would pose any fire danger, just sitting down there running. It is on a cement floor, next to a brick wall, plugged into a fused power strip. Also I was wondering how many watts this thing is eating, because although it continues to cool, if it is a threat, or hugely expensive, I'd probably shut it down. It was made in Poland, so if anything can go wring, it probably will. Thanks for any advice...Tree in KC
    Jul 2005
    61
    68
    Re: a-moan-ya
    It is an absorption chiller system most likely, an ammonia/water solution with a corrosion inhibitor. RV's use these powered by propane. Your description indicates it is run by an electric heat strip. I doubt that it is very efficient, otherwise you would see these more often. Mostly you see them run by propane/natural gas where electricity is not available/or expensive. There absorption air conditioners also. The disposal comes under Hazmat/EPA regulations due to the corrosion inhibitors more than the ammonia. Sodium chromate was one inhibitor that was used.
