I have the above model, and it seems to have a common problem (reading this and other sites).
The freezer is working fine, but the fridge is not cooling. I have switched off for 24hrs and turned back on but no joy, one thing I noticed before turning off, was one single lump of ice in the fridge compartment at the top of the right hand drainage run.
On other sites people talk about fans and ducts blocking up with ice, however there seems to be no compartments to take off for access, only the light housing that holds the thermostate.
Even the main metal sides of the unit seemed to be stuck and srewed.
Is there any way to gain access to check anything other than the compressor at the rear bottom?
Many thanks in advance.
