Results 1 to 13 of 13
Threaded View
13-01-2011, 11:03 AM #8
Re: Mitsubishi Ecodan Control Question
Ecodan uses standard central heating controls so a 2 channel timeclock and a room termostat are all the end user needs as an interface. If the cylinder is sized for a typical days hot water usage then the 1 hour boost on the 2 channel programmer will not need to be used frequently.
ASHPs can work well in northern scotland if the system is correctly designed and installed. The same applies to a GSHP (or any other form of heating), but if you have issues with one of these it can be even more difficult to rectify.
Mitsubishi "I Feel" Remote Control
By Rangie in forum Air ConditioningReplies: 5Last Post: 07-01-2009, 07:54 PM -
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Loading / Unloading Control Question...
By Bluenoser337 in forum Industrial CompressorsReplies: 31Last Post: 02-05-2006, 06:03 PM -
Control Question!
By balerjoe in forum IndustrialReplies: 4Last Post: 20-11-2005, 08:32 AM
