    2,534
    28
    "SPECIAL" screw compressor
    Have a process application which would run under following conditions .
    NH3 Economized VSD -33 C SST
    + 48 C SDT
    Apart from possible higher pressure rated casting would anything else have to be "SPECIAL" about it ?
    Anyone have experience ?
    Mar 2006
    Merate (LC) - Italy
    47
    2,553
    Re: "SPECIAL" screw compressor
    Why not a normal cascade system with NH3 on the low stage, and some other natural refrigerant on the high stage?
    Jul 2007
    Czech
    55
    332
    12
    Mar 2009
    U.S.A.
    300
    13
    Air cooled on R-717 is comparable to these conditions; considerable data on that in the IIAR technical sessions. Also more recently on using R-717 in central heat pump arrangements. Check the Vilter web site; they did nice work on a "small channel" single rotor screw for such purposes; high side to 85-deg C condensing.
    http://www.emersonclimate.com/Docume...%20Version.pdf
    MCR717's Avatar
    MCR717 Guest
    Limits on Vilter standard Single Screws are MAWP above 33 bar and pressure ratio 20:1.
    This application is within the limits, no need for their special high pressure compressors (MAWP 75 bar).
  1. Stal vertical screw compressor
    By Kota.Kumar in forum Technical Discussions
    Last Post: 06-11-2010, 08:17 AM
  2. Replies: 2
    Last Post: 19-10-2010, 08:56 PM
  3. Screw compressor failure
    By christossev in forum Industrial
    Last Post: 15-10-2010, 07:26 PM
  4. problem with volume on frick screw compressor
    By samlee12 in forum Industrial
    Last Post: 29-10-2009, 06:06 AM
  5. Replies: 7
    Last Post: 23-09-2008, 09:24 AM
