Thread: Help me pls
    Badran's Avatar
    Badran Guest
    Help me pls
    i will design small chiller system (2-4)RT but i need to initial point for start.
    one problem is how to select the cold water container size ?
    second stage how to select capacity of compressor for compression cycle so as given cold water .
    Finally;Best regards
    11,024
    Re: Help me pls
    First item - find book on theory of refrigeration, study it.
    Second item - Contact refrigeration expert to design it for you.
    Without correct knowledge you can not design.
    Nov 2010
    Germany
    120
    14
    Re: Help me pls
    Start from a refrigerant cycle and when you understand what is happening, come back and you will have some help definitely.
