Results 1 to 1 of 1
Thread: Samsung rs 20 cc
02-11-2010, 04:11 PM #1
Samsung rs 20 cc
Hi, just been to a rs 20 fridge freezer as normal freezing up the evap. Checked the evap pipe sensor seems ok ie the resistance alters when you touch the sensor. The thermal fuse is ok ie very low resistance. I have unplugged the two defrost elements and powered them from a seperate 240 volt supply and the both get hot. Any ideas, also how do you force a manual defrost from the front panel. Thanks
