02-11-2010, 01:40 PM #1
Ice Build Up - compressor problem
There is significant ice build up inside the fridge. An engineer informed me that this was due to a faulty compressor.
Is this possible?
02-11-2010, 02:05 PM #2
Re: Ice Build Up - compressor problem
No. It's probably low on refrigerant or faulty thermostat.
02-11-2010, 03:17 PM #3
hi duke,
if the comp, was faulty it would not run at all , ar it would run for a short space of time, then cut out,ice forming is as N,N,N , sayes short of gas, or stat, faulty. sedgy,
02-11-2010, 03:37 PM #4
Or the fridge is in a hot and humid space withe the door much time open or the seal doors are very damaged.
02-11-2010, 04:06 PM #5
Lots of possible causes for ice and frost buildup.
I'm not seeing how a bad compressor could cause it, though.
02-11-2010, 09:12 PM #6
What type of RCD does it have Tx valve or capillary?????
03-11-2010, 06:34 AM #7
if you are talking about a domestic fridge check the door seal and thermostat
Student project: Build a refrigerator
By Svenvbin in forum Technical DiscussionsReplies: 5Last Post: 06-05-2010, 02:57 PM -
What would be needed to build an approx 14cu/ft refrigerated box?
By oldpaddy in forum FundamentalsReplies: 4Last Post: 03-02-2010, 05:43 PM -
How to build a refrigerated warehouse
By acvr in forum Technical DiscussionsReplies: 2Last Post: 27-06-2009, 12:01 AM -
Want to build a refrigerator-like cooling for my cpu
By PeeWee in forum CPU OverclockersReplies: 50Last Post: 13-11-2008, 05:37 AM -
Custom Refrigeration Build
By pizza_boy in forum CommercialReplies: 11Last Post: 16-10-2007, 09:06 PM
