01-11-2010, 07:38 AM #1
Technical Specification on cold store
Dear Sir
I have a cold store size 4000x3750mm i want to select evaporator and condensing unit for these cold room having temperature +3 and -18 degree Celsius can anybody guide me how to do the selection for these cold room,the heat load for each room,evaporator temp.condensing temp capacity of the condensor ........Thanks
manuel
01-11-2010, 08:27 AM #2
Re: Technical Specification on cold store
Hi menezes2010
u should calculate the heat load to get the cooling capacity u need 4 this room, so u need 2 determine the products that u want 2 store in this cold room, the insulation type & thickness, the no of people working in it, the ligthning load, infilteration load. after all these estimations u get the capacity in Kw, TOR or Hp what ever it is u buy a refrigeration machine with this capacity & it's already attached with the corresponding evaporator & all other parts.
I think u didn't use the right forum, u should use Technical Discussion forum instead of Refrigeration book u've used.
Thank u
SonicLast edited by sonic; 01-11-2010 at 10:58 AM.
10-11-2010, 09:16 AM #3
Can u send formula for select the evaporator coil and condensing coil & fan selection
18-11-2010, 12:17 PM #4
cold store sliidng door & rapid door combination
By smpsmp45 in forum NH3Replies: 2Last Post: 29-06-2009, 05:32 AM -
farm cold store (need help)
By amin in forum Technical SpeculationsReplies: 5Last Post: 18-06-2009, 09:43 PM -
Cold Store Panel
By snow_man in forum Trouble ShootingReplies: 2Last Post: 31-07-2008, 08:05 AM -
Expansion Joints in the cold store floor
By smpsmp45 in forum NH3Replies: 2Last Post: 17-05-2008, 07:47 AM
