Results 1 to 2 of 2
Thread: Candy Fridge Freezes Up
30-10-2010, 11:02 PM #1
I have a Candy Integrated Firdge Freezer Model CIC 324 AK and the fridge part keeps freezing up. I have tried turning down the settings and have also tried turning it off at the mains and leaving both doors open for 24hours then back on but it keeps freezing the food and the back panel has frost on it, which i have scraped off several times. The doors seem to have a good seal.
Does anyone know how to overcome this problem?
31-10-2010, 11:49 AM #2
Re: Candy Fridge Freezes Up
The sensor for the fridge is faulty, you get to it from the back outside the cabinet. It's at the top buried inside the insulation, not an easy job as you have to dig into the insulation and make sure you don't go all the way through to fridge and don't cut into any pipes. After you've changed it you have to replace the insulation that you cut away with expandable foam
Candy fridge freezer working intermittently -HELP!
By charleylousy in forum DomesticReplies: 1Last Post: 17-08-2010, 08:44 PM -
very cold Candy Fridge Freezer please help...
By purplyblue in forum DomesticReplies: 1Last Post: 05-07-2010, 11:04 PM -
Candy Fridge Freezer not working properly
By darko.josifovsk in forum DomesticReplies: 1Last Post: 22-04-2010, 09:58 PM -
Need help with my Candy Fridge Freezer
By darko.josifovsk in forum DomesticReplies: 2Last Post: 22-04-2010, 07:54 AM -
Candy Fridge Freezer - Fridge Freezing Up
By laverda in forum DomesticReplies: 2Last Post: 24-02-2010, 09:20 AM
