    Oct 2010
    honduras
    43
    hoshizaki small cubes troubles
    hi am new on the forums trying to get help i buy hoshizaki km2000sfw3 water cooled i run the machine yesterday the first cycle take 1 hour and big big cubes nices cubes
    2cond cycle normal cubes
    3er cycle unnomal cubes
    the machine have more of 10 cycles with unnormal cubes i check the dip switch 10 digits
    1,2 off 3456 on 7,8,9,10 off
    my question is how i can configurate the DIP SWITCH TO GET A MORE LONGER CYCLE BECAUSE SHES MAKING ICE AROUND 7MINUTES
    THE DEFROST TIME AROUND 3 MINUTES SOME BODY CAN explaim me little more?
    sorry for bother also poor english am just trying to solve my problem
    sorry if bother you with my poor english
    Sep 2003
    ISRAEL
    72
    4,248
    Re: hoshizaki small cubes troubles
    the dip switch is a timer, look at carefully and work out the set time.
    when you work it out, you can make the cycle longer or shorter till the ice cubes satisfy you.
    The ice cubes should be crystal clear, thats the best.
    Oct 2010
    NJ, U.S.A.
    8
    float switch initiates harvest for hoshi's .. only harvests on time when it reaches 60 minutes which is a safety .... harvest is time controlled after suction line thermistor reaches set temp(off top of my head im guessing 48.6, or close to it)..... is the machine clean ? model & serial could be useful for more technical help ... or maybe call someone qualified to work on it
  1. Air conditioning set-up for small van
    By DesCallaghan in forum Transport
    Last Post: 06-09-2010, 06:23 AM
  2. small capacity Evaporator Pressure Regulator
    By majo in forum Trouble Shooting
    Last Post: 15-07-2010, 03:18 AM
  3. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  4. Daikin 7kW Cassette +supply duct to small office
    By Makeit go Right in forum Air Conditioning
    Last Post: 12-12-2007, 03:41 AM
  5. Small Chillers
    By Sledge in forum Commercial
    Last Post: 08-05-2007, 05:41 AM
