Thread: setting suction pressure
28-10-2010, 03:08 AM #1
Hi guys, i am currently working with a 3hp hitachi condensing unit, bohn let 120 evaporator and, danfoss ts2 TXV. currently i am getting 25psig (r404) suction pressure. I want it to go down to 20 psig (r404) suction pressure. how do i attain this? do i have to adjust the expansion valve?
28-10-2010, 03:20 AM #2
Re: setting suction pressure
Is the box at temperature?
If not, wait until it is very close to temperature before adjusting anything.
28-10-2010, 07:49 PM #3
Is the TXV correctly sized?
28-10-2010, 09:08 PM #4
The suction pressure is not something to be set. It will be whatever it needs to be given the current conditions.
Why do you want it to be 20psig?
30-10-2010, 08:09 AM #5
you do not set the suction pressure you set the super heat at the tev
30-10-2010, 10:50 AM #6
You don't set the suction pressure as previously stated, the suction pressure will vary depending on the load. If your superheat is set right the evap coil is doing all it can. Maybe you have other problems with this system. If you have all other temps/pressures etc and what you are trying to obtain temp. wise we can assist further. good luck
what is useful of Economizer?
By Ahmed.ragab in forum Industrial CompressorsReplies: 33Last Post: 18-08-2010, 12:15 PM -
york 5 ton ac low suction line pressure
By greenhornBC in forum Air ConditioningReplies: 0Last Post: 29-01-2010, 03:55 AM -
suction pressure regulation
By chillyblue in forum CommercialReplies: 15Last Post: 26-04-2008, 05:53 PM -
Cycle Stops at Low Suction Pressure
By verstep in forum History of RefrigerationReplies: 6Last Post: 30-10-2007, 11:05 PM -
propane compressor suction drum
By Ahmed_LNG in forum RefrigerantsReplies: 7Last Post: 01-01-2006, 08:01 AM
