Thread: fault code
26-10-2010, 07:19 PM #1
fault code
HI Guys,
Any one came across a mithsuvita wall type.Error code is E5.It is correctly charged.Condenser fan motor running fine,compressor the same.I first suspected the indoor coil thermistor but has nothing to check against.I tried even removing thermistor temporarily from holder but did the same.Any ideas what can be the cause of error.
26-10-2010, 07:52 PM #2
Re: fault code
Sorry, can't find that manufacturer name anywhere.
27-10-2010, 06:38 AM #3
Re: fault code
can it be a KFR ! Since here in Malta some are importing without name and naming their a/c . That's a good fraud ! I thank you and will try and get in detail more on the brand.
Mitsi Heavy E57 fault code in Error Log on wired controller
By back2space in forum Air ConditioningReplies: 10Last Post: 13-10-2010, 09:24 AM -
Mitsubishi 1500 fault code fault
By pie man in forum Air ConditioningReplies: 9Last Post: 06-05-2010, 09:30 PM -
Sanyo Text Back Fault Code Service
By techguy in forum Air ConditioningReplies: 1Last Post: 04-02-2009, 06:57 PM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM
