    donato35's Avatar
    donato35 Guest
    Altherma defrost algorithm
    Hi!!
    Do you know the algorithm used (altherma) in the defrost opereretion?
    Tks
    Donato
    Oct 2001
    Nottingham UK
    5,668
    Re: Altherma defrost algorithm
    Are you planning to alter the software Algorithm or just understand it?
    According to Wikipedia(sp?) .....
    "Each algorithm is a list of well-defined instructions for completing a task. Starting from an initial state, the instructions describe a computation that proceeds through a well-defined series of successive states, eventually terminating in a final ending state. The transition from one state to the next is not necessarily deterministic; some algorithms, known as randomized algorithms, incorporate randomness."
    donato35's Avatar
    donato35 Guest
    just understand it...:-))
    Tks
    Nov 2007
    London
    461
    this will vary from outdoor temp to outdoor coil temp and compressor accumulated running time. this is detailed in the service manual which can be downloaded from the extranet
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. maytag fridge activation of new controller
    By jdrefrigeration in forum Domestic
    Last Post: 09-03-2010, 12:00 PM
  3. Toshiba RAV SM/SP1400 defrost problem
    By SteinarN in forum Heat Pumps
    Last Post: 20-02-2008, 04:25 PM
  4. No Power for Defrost Timer Motor
    By kln in forum Domestic
    Last Post: 21-01-2008, 08:22 AM
  5. Hot gas defrost vs Electric defrost
    By herdian in forum Industrial
    Last Post: 13-08-2007, 11:25 PM
