    leoonheart07's Avatar
    leoonheart07 Guest
    brine tank calculation
    could anyone help us with the brine tank calculations? formulas and samples? we are conducting our thesis and we need how to compute the volume of the brine needed to convert a certain mass of water into ice. thanks..
    Nov 2010
    Germany
    120
    14
    Re: brine tank calculation
    Hi there,
    i am not sure that i understand the question...do you mean the volume of brine that should be sufficient to freeze some amount of water? Or you meant something else..Try to post some schematic view of what you want and i will try to help you
    leoonheart07 Guest
    you understood it right.. can you helpl me? or how do you design a brine tank? calculations? formulas? samples pls.. thanks..
    Nov 2010
    Germany
    120
    14
    I am on holiday up to next week and my scripts are at my work place..If that is not to late i will give you the formula next week
    Be careful about reading health books. You may die of a misprint.
    Nov 2010
    Germany
    120
    14
    Q ∆ϑ = Usable heat quantity for charge or discharge process in [kJ] or [kWh], dependent on the temperature difference ∆ϑ between tank supply and return
    V St = Tank capacity in [Liter]
    ρ = Density of the heat carrying medium [kg/l] p = Specifi
    c heat capacity of the heat carrying medium, kJ/(kg*K)
    η = Level of tank utilization [-], at maximum capacity η=0.9
    ∆ϑ = Difference between tank supply and return temperature
    Q∆ϑ = VSt ρ cp η ∆ϑ [kJ]
    and from this you can easily find the tank volume.
    Use sum of latent and sensible heat.
  1. Replies: 14
    Last Post: 05-01-2011, 12:12 AM
  2. Calculation bypass buffer tank volume
    By abbasi in forum New Technologies
    Last Post: 16-10-2008, 06:19 AM
  3. size of brine tank
    By boy in forum Air Conditioning
    Last Post: 29-07-2008, 03:03 PM
  4. How an expansion tank works?
    By Raadster in forum Fundamentals
    Last Post: 25-07-2008, 02:25 PM
  5. oil in tank heat load calculation
    By abbasi in forum Fundamentals
    Last Post: 13-06-2005, 08:36 AM
Tags for this Thread
