hi, new to the forum but and have found some very helpfull advice all ready.
im mainly an ac engineer but have started doing a bit of refigeration serbvice work also.
just a couple of questions if anybody can help.
1. how long does a system have to be running for before you calculate superheat and subcooling.
i.e does the room or container have to down to desired temperature. to get accurate results??
2. for example, evaporator with air flow i.e fan motor.. you minus 12 degrees from evaporating pressure/temp on comparitor to find expected evaporating temp. how much do you minus to find evaporating temp for plate heat exchanger, say for a reach in freezer.
hope you can help with this
