25-10-2010, 09:34 AM #1
Required temperature output from chiller is not obtained
Vapor compressor chilled brine plant:
30 TR capacity, -25 C is the required output
Problem: Temperature is not going beyond -14 C
Brine: 50% - MEOH + 50% - Water
SPG: 0.93
Refrigerant: Ammonia
Chiller Type: Shell & Tube, 6 pass
Compressor Discharge Pressure: 12 kg/cm2
Compressor Suction Pressure: 0.15 kg/cm2
Difference in Temperature around chiller: 1.5 C
Chiller Area is 45 m2
25-10-2010, 01:44 PM #2
Re: Required temperature output from chiller is not obtained
heat load excessive or cooling capacity insufficient.
25-10-2010, 01:56 PM #3
No excessive heat load because it is under recirculation mode from tank to chiller to tank. Cooling capacity is sufficient because liquid ammonia from condenser is at 38 C
25-10-2010, 02:39 PM #4
Cooling capacity is sufficient because liquid ammonia from condenser is at 38 C[/quote]
Huh? I am not an ammonia guy but this dosnt seem to make sense, someone please explain
25-10-2010, 06:17 PM #5
Both concept don't make sense at all.
Condensor split temperature
By Peter_1 in forum FundamentalsReplies: 14Last Post: 31-07-2011, 05:49 PM -
This a long one - AKV
By Peter_1 in forum IndustrialReplies: 6Last Post: 26-12-2008, 11:47 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM
