Results 1 to 1 of 1
    Oct 2007
    Mexico
    44
    158
    PVC Air Ducts for underground insulation Freezer Rooms
    Hello!
    I need help to get more info about this, the ASHRAE Refrigeration Handbook recommend this about Freezer insulation systems using air ducts:
    "The air duct systems works well for smaller storages. For a larger storage, it should be supplemented with fans and a source of heat if the pipe is more than 30m long."
    I've seen small Freezers using this method, using 4" PVC pipe underground. But in my case I have a very large Freezer room at -20ºC, 105m x 12m, and the PVC pipes can only be installed at the 105m long way, so I have lots of questions:
    This system still works for this long of pipes?
    How can I calculate the diameter of the PVC pipes?
    How can I calculate the airflow that fans are supposed to trow?
    How can I determine if extra heat source is needed?
    Can you help me please?
    P.D. I'll also use a 4" thick polyurethane foam and vapor barrier system not just the air ducts indeed.
    Thanks.
    Regards.
  1. Product Load Calculations for Freezer Rooms and Chiller Rooms
    By janroy in forum Technical Speculations
    Last Post: 07-10-2010, 05:55 PM
  2. Insulation test for cold rooms
    By evapcoil1 in forum Commissioning
    Last Post: 25-09-2010, 07:26 AM
  3. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  4. Insulation betweem separate Fridge and Freezer
    By Jim30 in forum Fundamentals
    Last Post: 13-07-2008, 08:55 PM
  5. Vertical Insulation freezer panels
    By samiam in forum Industrial
    Last Post: 07-05-2008, 05:03 PM
