21-10-2010, 03:39 AM #1
Theoretical Discharge Temperature
How do you calculate or determine the theoretical discharge temperature of an ammonia screw compressor?
22-10-2010, 08:04 AM #2
Re: Theoretical Discharge Temperature
Drawing the cycle in a log p/h
22-10-2010, 11:40 AM #3
Many manufaturers sw give also the discharge temperature so you can compare it with the p-h diagram
iw
22-10-2010, 12:04 PM #4
Must have in mind that the cooled oil decrease the discharge temperature of the superheated refrigerant.
22-10-2010, 12:49 PM #5
^ That's a very interesting point.
Do you perhaps have any observed information on this effect?Engineering Specialist - Cuprobraze, Nocolok, CD Technology
22-10-2010, 07:12 PM #6
23-10-2010, 05:03 PM #7
24-10-2010, 10:57 AM #8
Most manufacturers have either tables or a programe that can determine it .
Some things that affect it are ,
Oil temp into comp, oil cooler designed temp , amount of oil going into compressor , pressures of system , suction superheat , screw condition , type or brand of machine .
I would suggest between 60-85 deg C
A booster usually approx 10 deg C lower than high stage .
Superheat and Subcooling
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
