Results 1 to 8 of 8
    Nov 2006
    At home
    181
    Electronic Leak detector
    I am wanting to buy a electronic leak detector for work but was wondering which models you guys have and your experience with them?
    I am working mainly with HFC refrigerants
    Jun 2009
    North East England
    41
    712
    Re: Electronic Leak detector
    tecmate from climate center about £200 had one for years never let me down
    Nov 2006
    708
    23
    Javac Detek absolutely the best
    Nov 2006
    At home
    181
    thanks guys will look at both of these tools, anyone else got any input?
    May 2006
    Isle of Wight, Uk
    47
    424
    Don't get the yellow jacket one. I had one that failed second time I used it, the replacement one wasn't any better. Ended up with a tek mate, very sensitive to dust and wind though.
    Andy
    Jul 2009
    Switzerland
    11
    have the best experience with the ZX-1 from TIF
    Apr 2008
    Southampton, England
    49
    1,023
    36
    D Tek Select (the white one).
    Found it to be totally accurate when used correctly. Doesn't like getting leak spray down its throat though, and at £50 for a new IR cell yer pocket wont like it either.
    Also used a TIF XP1A. My morning turd would have found more leaks than that thing.
    Easy on the fig rolls,
    Andy.
    Start the Bench's Avatar
    Start the Bench Guest
    I like the D tek select too, however you have to right on the leak. It is the only one I know of that can pick up R410a though. I like the fact that the probe is long and you can bend it to reach around coils. It is my backup leak detector. The primary being a Yokogawa H10. That thing is pretty sensitive. If the leak is in an evaporator coil, the H10 can sniff it out through the condensate drain line. With the D tek, you have to be right on the leak.
  1. Electronic leak detector
    By langy in forum Air Conditioning
    Last Post: 27-08-2010, 01:10 PM
  2. Fieldpiece Leak Detector
    By Bones in forum Refrigerants
    Last Post: 05-09-2009, 04:49 AM
  3. USX Ultrasonic Leak Detector advice
    By rick19821982 in forum Tools and Calculators
    Last Post: 24-06-2009, 08:43 PM
  4. fieldpiece leak detector
    By richelli in forum Tools and Calculators
    Last Post: 02-07-2008, 11:44 PM
  5. Tiff 5000 leak detector
    By davidchesson in forum Tools and Calculators
    Last Post: 06-11-2006, 04:26 AM
