    Jul 2009
    Berkshire
    175
    15
    VRF refrigerant leak
    I was recently told by a technical department that an ac system that is short of refrigerant would be more apparent in HEAT mode rather than COOL mode; based on air on/off temperatures on indoor units.
    I always understood that HEAT mode used heat of compression as well as phase-change to generate really efficient heating that demanded less power input. And in COOL mode you relied only on refrigerant phase-change for cooling effect.
    Can someone please explain this to me?
    If at first you DO succeed, try to hide your astonishment!!
    11,025
    Re: VRF refrigerant leak
    Explain what?
    The phase-change statement or the tech dept statement?
    Jul 2009
    Berkshire
    175
    15
    Explain why a lack of refrigerant is more apparent in HEAT mode rather than COOL mode?
  1. Mitsubishi Gas leak? PURY P250 YGMA
    By marc5180 in forum Air Conditioning
    Last Post: 31-12-2010, 07:28 PM
  2. Pressure testing using a trace of refrigerant.
    By crit71 in forum Air Conditioning
    Last Post: 06-08-2010, 12:07 AM
  3. which refrigerant ???????
    By bob007 in forum Trouble Shooting
    Last Post: 31-05-2010, 12:54 PM
  4. Newbie. Charging Refrigerant. Mitsubishi SRK 40HG.
    By smoking_muzzle in forum Air Conditioning
    Last Post: 24-07-2007, 10:33 AM
  5. Is leak of refrigerant dangerous to HVAC?
    By stalker in forum Technical Speculations
    Last Post: 13-03-2006, 01:47 PM
