Thread: Solar AC split unit
18-10-2010, 11:12 AM #1
Solar AC split unit
Dear All
I'm wondering about the solar colector attached to the solar AC split unit, what is the working fluid in the tubes of the solar collector? is it gas or liquid?
Thanks for help
Sonic
18-10-2010, 11:52 PM #2
Re: Solar AC split unit
Give a clue as to the make or model.
19-10-2010, 08:32 AM #3
a good read:
http://www.bsee.co.uk/news/fullstory...the_facts.html
any one seen one?Paul
"KEEP IT COOL"
20-10-2010, 12:36 PM #4
Thank you 4 help, here u r:
the lable; wall mount split type solar air conditioner TKF-60w
Input power 1350-1560 w
Cooling capacity 20,000 Btu/h
R22
Rated current 6.14-7.09
Circulating blast volume more than or equal 850 qupic meter/h (I dont understand this term)
Charge 1.8 kg
20-10-2010, 01:09 PM #5
Thank u MR Superswill 4 this link. IT talks about solar PV but my AC is solar thermal using tube type collector (Active) as there is compressor in it.
( any 1 seen 1? ) do u mean the Solar AC (I'm talking about), compnents & working principle could be different than I expect.
Sonic
21-11-2010, 07:57 AM #6
Thanks alot
21-11-2010, 10:06 PM #7
I think that this unit uses the waste condenser heat to heat the solar collector tubes as well as the sun.
I have also seen pictures of the solar section being mounted alongside the condenser.
The fluid in the tubes could be plain water or it may be a glycol mixture.Brian - Newton Abbot, Devon, UK
Split A/C unit not working in heat pump mode
By Matt34 in forum Trouble ShootingReplies: 1Last Post: 12-03-2010, 02:01 PM -
Fault on a Hitatchi split unit.
By marc5180 in forum Air ConditioningReplies: 11Last Post: 14-02-2008, 07:38 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM
