17-10-2010, 11:48 AM #1
Daikin Siesta condensor ( loud high frequency inverter noise )
Hi i have a Daikin siesta ARX35 GV1B 3.5 m pipe run
18 months working no problems other than its always had a very loud high frequency inverter noise from the condensor audible from 8m away
Does anyone have any ideas how to silence it
Thanks Nick
17-10-2010, 07:47 PM #2
Re: Daikin Siesta condensor ( loud high frequency inverter noise )
they mounting havent come loose have they
18-10-2010, 04:56 PM #3
hi James Mountings are ok
noise is electronic from the inverter or compressor could this be linked to the short pipe run
thanks nick
18-10-2010, 06:38 PM #4
how short is the pipe run check the following for full tech info on this unit
http://extranet.daikin.co.uk/login.htm
Hello and help please with daikin inverter
By classic in forum Air ConditioningReplies: 8Last Post: 09-09-2010, 10:48 PM -
Daikin VRV III loud noise diagnosis needed.
By crmont in forum Trouble ShootingReplies: 10Last Post: 21-07-2010, 08:11 PM -
Daikin Super Inverter Questions - New Controller, Zoning and Fan Control
By lemannsquattro in forum Heat PumpsReplies: 4Last Post: 17-07-2010, 01:21 AM -
Daikin inverter not ramping up
By marc5180 in forum Air ConditioningReplies: 8Last Post: 06-07-2010, 08:21 PM -
Daikin Noise Levels, Please Help
By gwilliamson in forum Air ConditioningReplies: 4Last Post: 28-02-2007, 08:26 PM
