Thread: Coolroom issue
    Mar 2009
    42
    12
    Coolroom issue
    I have a coolroom that is running off a mechanical tstat Ranco . The Evap fans are set to cutout with tstat and pump down system is what seems to be the setup . Access is an issue to check system setup , Now the Evap is fully iced up i want to add a digital controller to control anti cycle and defrost but this is a SHELL refinery site and its a major ISSUE to alter any wiring and gain access to run wiring so i dont want to go near that option . Can any1 suggest a quality timer to wire into the condenser its just a small kirby condenser . I think this will solve my issue and just replace the thermostat and setup correctly to prevent icing as the refrigeration system seems to be working well . Im in australia so a timer from a major electrical company is useful . Thanks for any help
    Jan 2009
    Scotland
    79
    Re: Coolroom issue
    How about allowing evap fans to continue running when condensing unit has cut out. This should help to reduce ice build up on the coil.
    Dec 2008
    Portugal
    48
    1,020
    Re: Coolroom issue
    good point
    Auckland
    74
    3,357
    37
    Re: Coolroom issue
    As per previous suggestion, keep fans running in off cycle and get an air defrost of coil. I have a preference to use LP switch to cycle compressor so as to ensure a clear coil, rather than stat and pump down. The plus side is if coil ices up before design temp., due to door open etc., the system will stop and defrost when required as opposed to stat forcing it to run on. Takes time to set up LP settings but system will be bullet proof.
  1. LG Multisplit ongoing issue... slowly getting there I think!
    By back2space in forum Air Conditioning
    Last Post: 14-01-2011, 08:18 PM
  2. Coolroom Freezer WIRING CONFIGURATION
    By acura in forum Commercial
    Last Post: 17-10-2010, 06:04 PM
  3. Daikin output overcurrent issue
    By wilson77 in forum Air Conditioning
    Last Post: 18-01-2010, 11:36 PM
  4. Beko Fridge freezer - freezer temp issue
    By lukas989 in forum Domestic
    Last Post: 30-09-2009, 05:29 PM
  5. Flood back issue?
    By Arc in forum Trouble Shooting
    Last Post: 28-10-2008, 03:40 PM
