14-10-2010, 11:17 AM #1
Air to air Source Heat Pump DIY Design Help
Hi I am new here, and i guess a little cheeky, so please be gentle!
I have a quite large garage at home here in the UK its approx 10m * 8m where I am tinkering on some old cars, its starting to get colder... the roof and walls are reasonably well insulated but the floors cast concrete and cold just like the metal cars are...
I also have a small unused greenhouse next to it.
I want to build a cheap (if there is such a thing!) DIY air to air source heat pump and site the intake inside it to pull a little extra heat out of the green house etc over the ambiant air temp... to raise the freezing air temp to at least a two jumper level! in the mid winter.
Has anyone got any helpful thoughts or easy to build plans using readily available economic parts? which a competent tinkerer could deal with?
Many thanks for any help
David
14-10-2010, 11:22 AM #2
Re: Air to air Source Heat Pump DIY Design Help
Buy a window rattler, you cound not even buy half the parts for the price of a manufactured unit!!!
14-10-2010, 11:40 AM #3
Agree, window rattler perfect for that situation.
14-10-2010, 04:19 PM #4
Jolly good idea.
14-10-2010, 04:22 PM #5
Thanks for the replies...
I am still hopeing that I can perhaps find something to adapt? if i can if not i will perhaps build a couple of multifuel burners or something... you see I am the sort of person who simply likes tinkering!
I built simple diy type solar water collectors which feed under the mass sand / concrete floors in the house. I pulled up the raised timber floors and lined the space with EPS and then rammed tons of dry sand around coiled poly pipe to a depth of about 2 1/2 feet which starts to warm up around mid late summer and seperate then a top coil on the concrete which runs from the boiler (after being prewarmed by "my" diy collectors... I make parts / tools for the cars... I tend to fix or modify or adapt... i enjoy it...
But I have never "seen" an air to air heat pump in the flesh and am "interested" to understand more and well "tinker"!
Heres hopefull....
14-10-2010, 04:44 PM #6
14-10-2010, 07:51 PM #7
Most of the window rattlers I have come across are not designed to work below 19C ambient in cooling. Can't say that I've worked on one that is a heat pump though.
Fujitsu UK do them http://www.fujitsu-general.co.uk/air...Window_2pp.pdf
Will cool when the ambient is above 21C and heat down to 0C - might work if it's always above 0C in your green house but for a 10x8 garage I would use 2 x rated at 4.3kW
Domestic Air Source Heat Pump
By borderfox in forum Heat PumpsReplies: 39Last Post: 01-02-2010, 12:51 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
water source heat pump
By gramcor in forum Air ConditioningReplies: 1Last Post: 11-03-2008, 12:06 AM -
Water Source Heat Pump
By aliugur in forum FundamentalsReplies: 1Last Post: 02-06-2002, 03:24 PM
