Thread: delta t and TD
12-10-2010, 02:03 PM #1
delta t and TD
Good day all
I know its accepted practice in our industry to use delta t when refering to the same media, eg air in / air out and TD when refering to two different media, refrig temp and air/water temp.
Could one of the boffins on the site provide some reference for this
frank14
12-10-2010, 03:16 PM #2
Re: delta t and TD
Hi Frank
Looking around the interweb I found this:
Delta (upper case Δ, lower case δ) is the 4th letter of the Greek alphabet. In the system of Greek numerals it has a value of 4.
The upper-case letter Δ is used as the symbol for:
- A macroscopic change in the value of a variable in mathematics or science.
- Any of the delta particles in particle physics.
The lower-case letter δ is used as the symbol for:
- A microscopic change in the value of a variable in mathematics or science.
- The Kronecker delta in mathematics.
- The Dirac delta function in mathematics.
- A mark for deletion in proofreading. The usage is said to date back to classical times.
Letters that arose from Delta include the Roman D and the Cyrillic letter De .
Not sure of the origin of the use though.
14-10-2010, 09:56 AM #3
Re: delta t and TD
Frank
Hi, Thanks for the reply.
I'm looking for a reference to show they have different applications and are not interchangeable when used in our industry
frank14
14-10-2010, 07:19 PM #4
Re: delta t and TD
Did you follow the link to the Macroscopic Change, which details the explanation you are looking for?
dt = a 'change' whereas
TD = a temperature difference
Also, this makes interesting reading http://en.wikipedia.org/wiki/Temperature
18-10-2010, 08:45 AM #5
Re: delta t and TD
Frank
thanks for the input
Unfortunately the hypothsesis of ergodicity and the Boltzmann constant did a slow Brownian motion way way past my brain.
Not sure if it was just my eyes playing up, but I still did not see a reference that says delta t refers to same media or TD refers to two different media.
frank14
Delta T at lower outdoor temperatures ?
By JOSHUA NAGE in forum Technical DiscussionsReplies: 1Last Post: 10-05-2010, 06:35 PM -
Delta RA Capacities
By Greengrocer in forum Air ConditioningReplies: 1Last Post: 23-10-2009, 05:14 PM -
Centrifugals with VSD VS Centrifugal with star delta starter
By vijay_study in forum FundamentalsReplies: 2Last Post: 25-07-2008, 11:13 AM -
question on delta T values in air conditioning work
By beachfronttech in forum Air ConditioningReplies: 2Last Post: 18-01-2008, 10:06 PM -
What is a typical Delta T over an air/refrigerant heat exchanger?
By rjsimmon in forum FundamentalsReplies: 12Last Post: 18-03-2007, 05:25 PM
