    pavithra_uk's Avatar
    pavithra_uk Guest
    Unhappy LG Refrigerator strange problem
    First, Im new one to forum.
    Problem is here:
    I have LG GR-262 series micom controlled refrigerator. brought mid 2006. cooling is ok. but problem is it uses too much power.
    at times it brought and later (tested on 2008) it consumed roughly 1 kwh per day.
    but now, it consumed more than 2.5 kwh per day.
    Ref is rated power of 106W 220V
    No door seal leaks, evaporator fan faults, clogs in air vents/drain. no faults in defrosting, no fault in micom/sensors.
    I think compressor draw too much current. is it possible ?
    I tested compressor current with Digital multimeter's AC current range. it show 1.33 Amp @ 220V input
    (after stabilized)
    I tested power consumption with analog watt meter it shows more than 160W consumed by compressor
    (that meter mesure only true-power)
    compressor is PTC start type. no fault in PTC.
    please, I need expert's ideas..
    pavithra_uk Guest
    Re: LG Refrigerator strange problem
    I forgot to told that temrature setting makes little changes in power consumption.
    today I checked the running time:
    35 minutes on / 25 minutes off
    @ mid setting
    Apr 2001
    79
    5,071
    35
    Take off the fiber cover at the bottom of the back and thoroughly clean everything. Make sure the fan underneath is working properly and the fan blade is clean. If it can't get rid of the heat, the power usage skyrockets.
    Old working dog's Avatar
    Old working dog Guest
    sounds like the air flow past condenser coil is bad. try brushing and vac. to clean out.. I still use an old bottle brush left over from my kids
  1. MFI AMP6855 defrost problem
    By gliderpilot47 in forum Domestic
    Last Post: 12-01-2011, 12:11 PM
  2. A strange problem
    By MuhengineeR in forum Air Conditioning
    Last Post: 27-10-2010, 05:21 PM
  3. Fujitsu Multi problem
    By BMS1 in forum Heat Pumps
    Last Post: 02-09-2010, 06:41 AM
  4. problem with GE air con power problem
    By Richie101 in forum Air Conditioning
    Last Post: 05-11-2009, 04:00 PM
  5. Hot start problem on VRV REYQ14M7W1B
    By cool#9 in forum Air Conditioning
    Last Post: 20-04-2007, 08:09 PM
