Results 1 to 11 of 11
    A Surveyor's Avatar
    A Surveyor Guest
    Question R22 availability
    Hi - can anyone tell me the true availibility of R22 and the cost. I am advising tennats with a couple of years to run on their leases and it is not necesserily in their interest to change refrigerant gas because the lease expires before the ban comes into effect.
    Thanks.
    Dec 2009
    Spain
    45
    229
    15
    Re: R22 availability
    At the begining of the year, in Spain, there were around 45.000tons of R22 in the installations. In the UK, it could be more or less the same quantity. You only need to recover and recycle, then you have a "very cheap" R22.
    Regards,
    Nando.
    DAOUDASYLLA's Avatar
    DAOUDASYLLA Guest
    in Mali you can got R22 (13.5 Kgs) cost 1oo$ us
    Oct 2008
    mallorca, spain,
    75
    768
    and there was I thinking that it may be in the best interest of worlds climate NOT to use R22 isent that what WE are about?
    May 2008
    Malta
    68
    67
    The current range of HFC refrigerants are not the end solution as we have solved the problem of ozone depletion but have actually increased global warming potential so I expect there will be a rethink in the near future,co2 and r600a or nh3 spring to mind.
    Coolbrezza's Avatar
    Coolbrezza Guest
    Does anyone know if use R22 is against the law in Europe?
    11,025
    Check out the Institute of Refrigeration website...
    http://www.ior.org.uk/ior_general.ph...or_general.php
    Click on - Environmental Information
    then
    click on - Guidance for End Users
    and finally
    click on - R22 Phase Out and F Gas Regulations
    Or direct... on the above link.
    Jul 2010
    wigan
    2
    Quote Originally Posted by A Surveyor View Post
    Thanks.
    Hi in Lancs R22 for 13kg £220,R417a is a drop in that works and cheaper than R22
    11,025
    Unless the system is broke, then don't fix it.
    Oct 2010
    INDIA
    5
    It is mostly used in Indian market & readily available tooo. It costs Rs 400/Kg.
    zdravlje's Avatar
    zdravlje Guest
    Quote Originally Posted by chilled444 View Post
    , here is R22 is 65 euro/china.. Something beter is 75 Eu...Serbia
  1. Carrier 42XPF100 spares availability
    By rob_h1978 in forum Air Conditioning
    Last Post: 11-02-2010, 11:08 AM
  2. Co2, The good,The Bad and your Thoughts,
    By supermarketguy in forum Supermarket Refrigeration
    Last Post: 20-03-2009, 09:16 PM
  3. R22 Availability
    By Jamie in forum Refrigerants
    Last Post: 07-09-2008, 02:13 AM
  4. R290 Care 50
    By ralph feria in forum Refrigerants
    Last Post: 24-02-2004, 02:53 AM
  5. R-114 cost & availability
    By Doug Carpenter in forum Industrial
    Last Post: 09-06-2002, 04:00 PM
