    RINBERT CG's Avatar
    RINBERT CG Guest
    Bitzer compressor unloader
    Hi everyone!
    I got some problem with the Bitzer unloader. After we install and activate the unloader the hi & low side balances the pressure. How are we going to address this problem. The supplier supplied only the cylinder head and the valves without changing the valve plate cover.
    Hope to received any answer from you. Thank you
    regards,
    RINBERT
    495
    Re: Bitzer compressor unloader
    Hi mate it could be several reasons , you might have start unloader instead of capacity control unloader, on the head it self it should say SU or CR. the valve plate does,nt need to be changed. or if you have a start unloader the valve piston in the head might be stuck open (at the top),to check take of the solnoid valve and see the piston goes up and down.
  1. Bitzer gasket
    By Renato RR in forum Fundamentals
    Last Post: 04-11-2010, 10:08 AM
  2. Bitzer s6f30 2-stage compressors
    By JONAH in forum Technical Discussions
    Last Post: 27-10-2010, 07:27 AM
  3. Bitzer CSH8561-125Y oil sight glass
    By Peter_1 in forum Industrial
    Last Post: 26-05-2010, 04:32 PM
  4. Bitzer screwpack vibrations
    By KosmisB in forum Trouble Shooting
    Last Post: 05-03-2010, 02:42 PM
  5. Oil pressure Bitzer
    By coolcmt in forum Commercial
    Last Post: 25-09-2009, 07:09 AM
