    mkhan_quickbird's Avatar
    mkhan_quickbird Guest
    Calculating the capacity of a heat pump
    I generally design heat pumps using commonly available refrigeration parts.a lot of guess work has to be done.kindly suggest me how much heat could be extracted per hour using a one ton a.c. Compressor.
    Eagerly waiting for a good suggestion.
    Khan
    Aug 2009
    New Zealand
    2,554
    26
    Re: Calculating the capacity of a heat pump
    Quote Originally Posted by mkhan_quickbird View Post
    Khan
    "Design", "guess" which is it? second I suspect, I would recommend that you go to school and study refrigeration, this will help you understand your question. Then you can ask again with all the info required to answer the question.
    I have a question "how long is a piece of string"
    Same question as yours
    Mar 2009
    KZN, South Africa
    64
    2,212
    LOL. I tried to answer this thread twice a few hours ago. Gave up as I felt that the OP needed to bring his own design calculations to the board, for checking & discussion.
    Aug 2009
    Phoenix, Az
    11
    Wow, the question alone does not really suggest designing...
  1. compressor for wind powered heat pump
    By tomwol in forum Technical Speculations
    Last Post: 12-11-2011, 01:05 PM
  2. Replies: 3
    Last Post: 29-04-2010, 10:30 AM
  3. Pool Heat Pump
    By elvis in forum Heat Pumps
    Last Post: 23-03-2010, 09:18 PM
  4. Sensible Heat Factor / capacity of Inverter split Systems at part load?
    By Greengrocer in forum Technical Speculations
    Last Post: 09-02-2009, 04:57 PM
  5. swimming pool heat pump
    By Andy AC in forum The Trail of Tears
    Last Post: 26-08-2007, 04:02 PM
